July 6, 2023 at 3:03 pm
I would like to use speeds. Because I have rotation and feed speeds and workpieces can be of different lengths. I need to watch how the teeth wear out depending on the workpiece and material.
Could you open the model and try to set the rotation and feed speeds?
Can I use remote displacement like this:
i have rotation speed it is 27 radian/sec can i set it as 1574 degree/sec?
feed 40mm/s, is it like moving 40mm per second?
