Assuming you are using Pressure based solver, please check if the Pseudo time method is ON or OFF. And in the Controls, check if the option to change the Courant number is available. If it is, then you need to use: solve/set/p-v-controls. Here, Fluent will give you an option to change the Control parameters and one of them would be Courant number.
