Concerning your first question, it could be due to a large timestep set. Please check that enough samples are taken in one period. Concerning your second question, the easiest way to create a pulse is through an external excitation using a Pulse Voltage Source. In the Pulse Voltage Source you can specify magnitude, duty cycle and frequency, as well as rise time and fall time.
