July 10, 2023 at 1:23 pm
Hi Rob,
Many thanks for the response.
Can I ask if you can explain on your response a bit more please, I still dont have the clarity on the parcel and particle concepts, and especially with fractional number of particles.
Also, can you please explain,
- If the particles are tracked, how are the equations solved for number of particles which is less than unity?
- You mentioned the terms were mis-used from the early days of Fluent's DPM model. Does this inconsistent in terminology still continue?
Thanks in advance.
