July 10, 2023 at 4:15 pm
Hello i tried all the suggestions you had mentioned. I set the courant number to 2.75 for about 1000 iterations and then changed it back to 5. I selected higher order term relaxations, disabled compressibility effects in k-w sst, reduced urfs, used green gauss node based gradient. The walls are adiabatic so heat flow was 0. But I'm still no where near convergence. I also used outlet pressure as a monitor . Pls help, thanks.
