Reno Genest
Hello Teng,
I checked in our system and the University of Cincinnati account you are associated with only has LSTC LS-DYNA (500 cores) which requires the LSTC license manager.
So, to run LS-DYNA from your machine, you have to point to the LSTC license server by setting the  following 2 environment variables on your Windows machine:
LSTC_LICENSE=network
LSTC_LICENSE_SERVER=hostname_or_ip_address_of_LSTC_license server
If you don't know how to set environment variables in Windows, please Google "how to set environment variables in Windows".
To run LS-DYNA, we recommend using LS-RUN. LS-RUN comes with the Ansys installation. If you don't have Ansys installed, you can download LS-RUN here:
https://ftp.lstc.com/anonymous/outgoing/lsprepost/LS-Run/win64/
Here is a video tutorial on how to use LS-RUN:
https://www.youtube.com/watch?v=ymkTJCefm30
Note that you can set the license information in LS-RUN and LS-RUN will set the environment variables automatically for you (as long as the Env Var check box is checked):
Put the LSTC license server hostname of IP address in the Server hostname field in LS-RUN (see image above).
Let me know how it goes.
Reno.
