Fluent doesn't have a grinding model. Fluent can give you parameters that can be used in an experimentally derrived correlation to calculate a grinding rate. So you can do the experiment on a simple, safe system and employ Fluent for complicated, dangerous and expensive enviroments as part of the design process.
