July 11, 2023 at 4:56 pm
Hi Usnish,
Thanks for your reply.
I looked at the paper that you proposed, but I couldn't find an explanation why I should use the Load_Body. I understand the Initial_Stress_Depth, but not the load_Body.
Another question, if I want to have zero initial effective stresses, how can I achieve that since the water pressures due to gravity are always calculated in LSDYNA?
Finally, I cannot get the output of the pore water pressures. I read the manual, but I cannot find the right way to get this output. Could you help me also with this?
Thank you very much.
