Hello Fang,
I recommend you to use the newest feature in 2023 r2 fluent version called the water corrosion pre tool option. I have attached the user guide link where they have clearly mentioned on how to set up the case and run the simulation.
18.1. Modeling Species Transport and Finite-Rate Chemistry (ansys.com)- Refer
I hope this helps you.
Thanks,
Chaitanya Natraj
