July 12, 2023 at 12:21 pm
Hi Dana,
Which version of the standalone fluent application you are using?
If you can use the v231 fluent standalone application but not through workbench, then follow the below steps:
Close all the Ansys applications.
Go to Startà search “Product and CAD Configuration 2021 R2” and run it as admin.
Follow the below steps: (while configuring products and unconfiguring products “select all” option)
- Install Required Prerequisites.
- Unconfigure Products & CADs.
- Configure Products & CADs.
Rename the Ansys folder to Ansys.old (%appdata%) and .ansys to .ansys.old (%temp%)
Launch the application again.
If you are not able to use the standalone fluent v231 application then it’s a licensing error.
Let me know if the above solutions work for you.
