July 13, 2023 at 8:21 pm
Hi Sathursan,
Thank you for sharing more information. I agree that most of the commands are for the simulation in analysis mode except for a few such as clearsourcedata and I believe you do not have an import source it would not have an impact. Would you be able to share a screenshot of the memory details (can be found when you scroll down the Simulation and Memory report window, example shown below)?
Also, you mentioned that in a few simulations, the size is reduced when you copy and paste the objects into a different file. Is that also the case for this simulation?
Amrita
