July 14, 2023 at 4:26 am
Thank you to reply.
The exact error is only this, "Error at host: Error code: 127"
OS of our work station is Windows. It has 56 CPU cores(Intel Xeon Platinum) and two Quadro GV100 GPU cards.
And following is "install.log".
Do you need other information to deal with this problem??
Start Installation: Wed May 31 09:55:11 2023
Revision: 2023 R1
Platform specifics:
Windows
Username of Installer: DESKTOP-IKV1H1S\STSEL
User Has Administrator Privileges
C:\Users\STSEL\AppData\Local\Temp\ans_install_tmp5696\instcore.exe -usetempdir C:\Users\STSEL\AppData\Local\Temp\ans_install_tmp5696 -launchdir G:\windows -admin -manifestFileDir G:\windows\manifest\license
Initial mount directory:
G:\windows
Installation Directory:
C:\Program Files\ANSYS Inc
Windows x64
Ansys, Inc. License Manager
Date verification complete...No conflicts found.
Reading the installation media contents - please wait.
Extraction: G:\windows\instcore\tcl\COMMON.TGZ ...
Extraction: G:\windows\instcore\tcl\WINX64.TGZ ...
Extraction: G:\windows\licserv\WINX64.7z ...
Extraction: G:\windows\lmcenter\WINX64.7z ...
Extraction: G:\windows\license\WINX64.7z ...
Extraction: G:\windows\clclient\WINX64.7z ...
Performing licensing configuration via the following command...
C:\Program Files\ANSYS Inc\Shared Files\Licensing\tools\bin\winx64\ansyslm_config.exe -install -lang en-us
Extraction: G:\windows\hlp\hlplic\HLPLIC.7z ...
Licensing configuration has completed.
Installation Complete: Wed May 31 09:56:47 2023
Start Installation: Wed May 31 10:05:06 2023
Revision: 2023 R1
Platform specifics:
Windows
G:\windows
Windows x64
Ansys, Inc. Products
Fluid Dynamics
CFX (includes CFD-Post)
Chemkin
Energico
Model Fuel Library (Encrypted)
Reaction Workbench
EnSight
FENSAP-ICE
Fluent (includes CFD-Post)
Forte (includes EnSight)
Polyflow (includes CFD-Post)
TurboGrid
ICEM CFD
Motion
Offshore
Aqwa
Optical
Speos
Platform
optiSLang
Structural Mechanics
Additive
Mechanical Products
Material Calibration App
Ansys Additional Tools
Icepak (includes CFD-Post)
Acoustics
Licensing files on the installation media have the same date or are more recent than those currently installed.
The files will be updated....
Date verification complete...Please see above messages for any detected conflicts.
The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.
You're missing required prerequisites.
Installing MS ASP.NET Hosting Bundle 6.0.8
Installing MS Desktop Runtime 6.0.8
Everything was successfully installed.
Extraction: G:\windows\framewrk\WINX64.7z ...
Extraction: G:\windows\instutil\INSTUTIL.7z ...
Extraction: G:\windows\instcore\tk\COMMON.TGZ ...
Extraction: G:\windows\instcore\tk\WINX64.TGZ ...
Extraction: G:\windows\configs\clientlicensing\WINX64.7z ...
Extraction: G:\windows\subs\WINX64.7z ...
Extraction: G:\windows\sgcharts\WINX64.7z ...
Extraction: G:\windows\fwgfx\WINX64.7z ...
Extraction: G:\windows\commoninstall\WINX64.7z ...
Extraction: G:\windows\configs\ansconfigdll\WINX64.7z ...
Extraction: G:\windows\common\WINX64.7z ...
Extraction: G:\windows\configs\common\WINX64.7z ...
Extraction: G:\windows\cpythext\WINX64.7z ...
Extraction: G:\windows\cpythcloudext\WINX64.7z ...
Extraction: G:\windows\cpythnew\WINX64.7z ...
Extraction: G:\windows\hlp\hlpviewer\HLPVIEWER.7z ...
Extraction: G:\windows\configs\help\WINX64.7z ...
Extraction: G:\windows\tp\7zip\WINX64.7z ...
Extraction: G:\windows\tp\angular-nvd3\WINX64.7z ...
Extraction: G:\windows\tp\angular-ui-context-menu\WINX64.7z ...
Extraction: G:\windows\tp\angular-ui-tree\WINX64.7z ...
Extraction: G:\windows\tp\angularjs\WINX64.7z ...
Extraction: G:\windows\tp\angularjs-slider\WINX64.7z ...
Extraction: G:\windows\tp\angularUI\WINX64.7z ...
Extraction: G:\windows\tp\bootstrap\WINX64.7z ...
Extraction: G:\windows\tp\d3\WINX64.7z ...
Extraction: G:\windows\tp\ffmpeg\WINX64.7z ...
Extraction: G:\windows\tp\IntelCompiler\WINX64.7z ...
Extraction: G:\windows\tp\jquery\WINX64.7z ...
Extraction: G:\windows\tp\ngInfiniteScroll\WINX64.7z ...
Extraction: G:\windows\tp\nvd3\WINX64.7z ...
Extraction: G:\windows\tp\qt\WINX64.7z ...
Extraction: G:\windows\tp\signalr\WINX64.7z ...
Extraction: G:\windows\tp\hdf5\WINX64.7z ...
Extraction: G:\windows\tp\zlib\WINX64.7z ...
Extraction: G:\windows\tp\openjre\WINX64.7z ...
Extraction: G:\windows\configs\wb\WINX64.7z ...
Extraction: G:\windows\addins\WINX64.7z ...
Extraction: G:\windows\addins\ansoft\WINX64.7z ...
Extraction: G:\windows\addins\matdes\WINX64.7z ...
Extraction: G:\windows\addincfg\wb\WINX64.7z ...
Extraction: G:\windows\corewb\WINX64.7z ...
Extraction: G:\windows\cads\cadaisol\WINX64.7z ...
Extraction: G:\windows\cads\cadregistry\WINX64.7z ...
Extraction: G:\windows\meshing\WINX64.7z ...
Extraction: G:\windows\pyprime\WINX64.7z ...
Extraction: G:\windows\blademodeler\WINX64.7z ...
Extraction: G:\windows\apipsrv\WINX64.7z ...
Extraction: G:\windows\designmodeler\WINX64.7z ...
Extraction: G:\windows\syscplg\WINX64.7z ...
Extraction: G:\windows\mechsrvplg\WINX64.7z ...
Extraction: G:\windows\rsm\WINX64.7z ...
Extraction: G:\windows\icemwb\WINX64.7z ...
Extraction: G:\windows\addincfg\turbosys\WINX64.7z ...
Extraction: G:\windows\cads\acispara\WINX64.7z ...
Extraction: G:\windows\sec\WINX64.7z ...
Extraction: G:\windows\spaceclm\WINX64.7z ...
Extraction: G:\windows\configs\spaceclm\WINX64.7z ...
Extraction: G:\windows\ccm\WINX64.7z ...
Extraction: G:\windows\ecadxltr\WINX64.7z ...
Extraction: G:\windows\cads\spatialiop\WINX64.7z ...
Extraction: G:\windows\aas\WINX64.7z ...
Extraction: G:\windows\cfxcomon\WINX64.7z ...
Extraction: G:\windows\addincfg\minerva\WINX64.7z ...
Extraction: G:\windows\addincfg\granta_gateway\WINX64.7z ...
Extraction: G:\windows\addins\granta_gateway\WINX64.7z ...
Extraction: G:\windows\addincfg\granta_selector\WINX64.7z ...
Extraction: G:\windows\addins\granta_selector\WINX64.7z ...
Extraction: G:\windows\cads\stride\WINX64.7z ...
Extraction: G:\windows\cads\hoops\WINX64.7z ...
Extraction: G:\windows\addins\injmold\WINX64.7z ...
Extraction: G:\windows\dpf\WINX64.7z ...
Extraction: G:\windows\tp\intelmkl2020.0.166\WINX64.7z ...
Extraction: G:\windows\cfx\WINX64.7z ...
Extraction: G:\windows\addincfg\cfx\WINX64.7z ...
Extraction: G:\windows\configs\cfx\WINX64.7z ...
Extraction: G:\windows\post\WINX64.7z ...
Extraction: G:\windows\addincfg\cfdpost\WINX64.7z ...
Extraction: G:\windows\tp\cpprestsdk\WINX64.7z ...
Extraction: G:\windows\chemkin\WINX64.7z ...
Extraction: G:\windows\configs\chemkin\WINX64.7z ...
Extraction: G:\windows\addincfg\chemkin\WINX64.7z ...
Extraction: G:\windows\tp\intelmkl2021.3.0\WINX64.7z ...
Extraction: G:\windows\configs\energico\WINX64.7z ...
Extraction: G:\windows\configs\rdworkbench\WINX64.7z ...
Extraction: G:\windows\ensight\WINX64.7z ...
Extraction: G:\windows\configs\ensight\WINX64.7z ...
Extraction: G:\windows\nexus\WINX64.7z ...
Extraction: G:\windows\fensap\WINX64.7z ...
Extraction: G:\windows\configs\fensap\WINX64.7z ...
Extraction: G:\windows\configs\cfdpost\WINX64.7z ...
Extraction: G:\windows\fluentc\WINX64.7z ...
Extraction: G:\windows\fluents\WINX64.7z ...
Extraction: G:\windows\fluenta\WINX64.7z ...
Extraction: G:\windows\fluentu\WINX64.7z ...
Extraction: G:\windows\fluentp\WINX64.7z ...
Extraction: G:\windows\fluentm\WINX64.7z ...
Extraction: G:\windows\fluent2d\WINX64.7z ...
Extraction: G:\windows\fluent2ddp\WINX64.7z ...
Extraction: G:\windows\fluent3d\WINX64.7z ...
Extraction: G:\windows\fluent3ddp\WINX64.7z ...
Extraction: G:\windows\addincfg\fluent\WINX64.7z ...
Extraction: G:\windows\configs\fluent\WINX64.7z ...
Extraction: G:\windows\distcomp\WINX64.7z ...
Extraction: G:\windows\ensight_components\WINX64.7z ...
Extraction: G:\windows\polyflow\WINX64.7z ...
Extraction: G:\windows\addincfg\polyflow\WINX64.7z ...
Extraction: G:\windows\addincfg\matpro\WINX64.7z ...
Extraction: G:\windows\configs\polyflow\WINX64.7z ...
Extraction: G:\windows\cff\WINX64.7z ...
Extraction: G:\windows\forte\WINX64.7z ...
Extraction: G:\windows\addincfg\forte\WINX64.7z ...
Extraction: G:\windows\configs\forte\WINX64.7z ...
Extraction: G:\windows\turbogrd\WINX64.7z ...
Extraction: G:\windows\configs\tg\WINX64.7z ...
Extraction: G:\windows\icemcfd\WINX64.7z ...
Extraction: G:\windows\configs\icemcfd\WINX64.7z ...
Extraction: G:\windows\addincfg\icemcfd\WINX64.7z ...
Extraction: G:\windows\motion\WINX64.7z ...
Extraction: G:\windows\motion_scdm_addin\WINX64.7z ...
Extraction: G:\windows\configs\motion\WINX64.7z ...
Extraction: G:\windows\aqwa\WINX64.7z ...
Extraction: G:\windows\addincfg\aqwa\WINX64.7z ...
Extraction: G:\windows\configs\aqwa\WINX64.7z ...
Extraction: G:\windows\speos\WINX64.7z ...
Extraction: G:\windows\configs\speos\WINX64.7z ...
Extraction: G:\windows\anscust\WINX64.7z ...
Extraction: G:\windows\cads\cat5\WINX64.7z ...
Extraction: G:\windows\speoslabs\WINX64.7z ...
Extraction: G:\windows\configs\speoslabs\WINX64.7z ...
Extraction: G:\windows\speosdata\WINX64.7z ...
Extraction: G:\windows\optislang\WINX64.7z ...
Extraction: G:\windows\configs\optislang\WINX64.7z ...
Extraction: G:\windows\addins\optislang\WINX64.7z ...
Extraction: G:\windows\addprint\WINX64.7z ...
Extraction: G:\windows\configs\addprnt\WINX64.7z ...
Extraction: G:\windows\addprintgeometry\WINX64.7z ...
Extraction: G:\windows\addprep\WINX64.7z ...
Extraction: G:\windows\ansys\WINX64.7z ...
Extraction: G:\windows\additive_cl\WINX64.7z ...
Extraction: G:\windows\configs\ansys\WINX64.7z ...
Extraction: G:\windows\addincfg\ansys\WINX64.7z ...
Extraction: G:\windows\addincfg\matdes\WINX64.7z ...
Extraction: G:\windows\solver\WINX64.7z ...
Extraction: G:\windows\data\DATA.GZ ...
Extraction: G:\windows\apdl\APDL.GZ ...
Extraction: G:\windows\python_site_mapdl\WINX64.7z ...
Extraction: G:\windows\geompara\WINX64.7z ...
Extraction: G:\windows\addincfg\mech\WINX64.7z ...
Extraction: G:\windows\acp\WINX64.7z ...
Extraction: G:\windows\addins\acp\WINX64.7z ...
Extraction: G:\windows\configs\acp\WINX64.7z ...
Extraction: G:\windows\shapeoptimization\WINX64.7z ...
Extraction: G:\windows\dpf\plugins_autodyn\WINX64.7z ...
Extraction: G:\windows\dpf\plugins_composites\WINX64.7z ...
Extraction: G:\windows\matcal\WINX64.7z ...
Extraction: G:\windows\cads\fusion\WINX64.7z ...
Extraction: G:\windows\icepak\WINX64.7z ...
C:\Program Files\ANSYS Inc\Shared Files\bin\winx64\tclsh.exe C:\Program Files\ANSYS Inc\Shared Files\Licensing\licadmin\scripts\LicAdminMain.itcl -silentinstallclient -release 2023 R1 -licserverinfo 2325:1055:DESKTOP-K6RPRKG -lang en-us
Extraction: G:\windows\addincfg\icepak\WINX64.7z ...
Extraction: G:\windows\configs\icepak\WINX64.7z ...
Extraction: G:\windows\hlp\hlpicepaksa\HLPICEPAKSA.7z ...
RSS is disabled
Creating Start Menu items for Ansys client licensing ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigCommon.exe
Configuring Help ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigHelp.exe
ANSYS Internet Doc has been configured.
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigWB.exe
Running C:\Program Files\ANSYS Inc\v231\Framework\bin\Win64\Ans.DriverSetup.exe
Running "C:\Program Files\ANSYS Inc\v231\RSM\bin\AnsConfigRSM.exe" -encodingUTF8
Configuring RSM...
Configuring default RSM and ARC Port numbers for 2023 R1 ...
Done!
User has Administrator privileges
Creating Start Menu Shortcut for RSM 2023 R1 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\RSM Configuration 2023 R1.lnk
Creating Start Menu Shortcut for RSM 2023 R1 Job Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\RSM Job Monitoring 2023 R1.lnk
Creating Start Menu Shortcut for RSM 2023 R1 Cluster Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\RSM Cluster Monitoring 2023 R1.lnk
Creating Start Menu Shortcut for ARC 2023 R1 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\ARC Configuration 2023 R1.lnk
Creating Start Menu Shortcut for DCG 2023 R1 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\DCG Configuration 2023 R1.lnk
Created Shortcut C:\Program Files\ANSYS Inc\v231\RSM\bin\HPCServices\DCG Local Portal.lnk
Created Shortcut C:\Program Files\ANSYS Inc\v231\RSM\bin\HPCServices\DCG Local Shutdown.lnk
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigSpaceClaim.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigCFX.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigCHEMKIN.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigEnergico.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigRDWorkbench.exe
Configuring EnSight ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigEnsight.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigFENSAP.exe
Configuring ANSYS CFD Post ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigCFDPost.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigFLUENT.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigPolyflow.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigFORTE.exe
Configuring ANSYS TurboGrid ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigTG.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigICEMCFD.exe
Configuring Motion ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigMotion.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigAQWA.exe
Configuring Speos ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigSpeos.exe
Configuring Speos Labs ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigSpeosLabs.exe
Configuring LS-DYNA ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigOptiSlang.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigAdditiveDesktop.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigANSYS.exe
Adding write permissions for Users and Administrators group ...
Configuring ACP ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigACP.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigIcepak.exe
Running "C:\Program Files\ANSYS Inc\v231\aisol\..\commonfiles\CAD\bin\winx64\Ans.CadInt.CADConfigurationUtility.exe"
Log files is C:\Program Files\ANSYS Inc\v231\CADConfigLogs\Latest\CADConfigurationMgr.log
MessageLogger.logFilePath is C:\Program Files\ANSYS Inc\v231\CADConfigLogs\Latest\CADConfigurationMgr.log
ErrorLogger.errorFilePath is C:\Program Files\ANSYS Inc\v231\CADConfigLogs\CADConfigurationMgr.err
Prerequisites ..... Configure Success
SC Workbench PlugIn ..... Configure Success
Discovery Workbench Plugin ..... Not Configured
Successfully created file associations.
Installation Complete: Wed May 31 10:17:31 2023
Installation Complete.
Thanks for choosing Ansys Products!
***IMPORTANT***
After completing this installation, you need to run the Ansys, Inc. License Manager installation on each machine designated as a license server. These machines may have been specified during this installation or may have been previously specified.
***WARNING***
NVIDIA driver missing or deprecated. Please install or update NVIDIA driver to version 471.68.
Speos Live Preview and Speos GPU Compute require NVIDIA GPU from Pascal generation or newer and driver version 471.68 or newer.
