July 14, 2023 at 12:05 pm
Hi Devika,
Many thanks for the reply. The initial parameters I meant is the exact value. For example, I had the best solution parameters of the interrupted optimization, but it is still not the best structure, so I want to use the parameters as the first generate parameters of the new PSO process to avoid totally random initial parameter, for saving time. Hope I expained it clearly.
