WooMin Jang
Thanks!
But I wonder that in umat44v, there only exists one code line to use umat with eos.
I also did that, But it didn’t work with any built-in eos in simple newtonian fluid code i defined.
But, in nonsense, it works very well with user-defined eos, where there is pc(i) for pressure-cutoff.
what would be the cause of this difference?? (Is ‘c$omp threadprivate (/eosdloc/)’ essential for setting pc?)
Already, i said i suppose pc(i) will be the cause… and what could be the solution??
I’m very confused…
P.S. what are 4 history variables stored exactly in order ??
Thank you for your sincere help.
