Many, many sources of potential error. Here are the simpliest do debug.
- Is it scaled correctly? Are you sure of your HEx size in the Fluent model? It would not be the first time someone made this mistake.
- Does it have the correct material properties? Default is air.
- Double check your mass flux. Does it match what you put in your hand calculation?
