It's not, but I don't know what the hole size is relative to the domain. An 0.1mm hole will want 15 or so cells across to get the flow field right, but if your domain is at the cm scale the cell count could be rather large. Similarly, if you use too many local sizing constraints the mesher will need to work out how to meet all of these requirements.
