July 17, 2023 at 8:52 pm
I'm using APDL, the model is very simple, just a square composite laminate modeled using APDL commands. simple description of the model: SHELL281 & REINF265, simply supported, pressure load applied on the top and then released, transient analysis, two load step files.
for the results, I'm looking for the response of the node at the centroid in the z-direction.
hope this is the info you asked about!
