Ok, the procedure was slightly different but the end result is fine. The easiest way is to modify an already existing material.
I think that this will do!
One more question: if the initial curve has changing curvature as the one that is presented in Maxwell manual, does Maxwell calculates the BH relationship from the initial curve or the ascending/decending curve?
Thank you
