I cannot see the exact error. Can you try increasing the substeps or number of iterations? By default Mechanical uses 25/26 iterations. You can increase this value by issuing a command under setup branch. Use the command: neqit,50 (no. of equilibrium iterations =50).
Ashish Khemka
