Erik Kostson
Hi
If you have spring stiffness in the bearings in the Y-Z plane and remote disp. as you have it should be ok.
Yes, look into the weak springs (so set them to On), and also turn off pivot check also (Solver pivot checking – under analysis settings)
All the best
Erik
