It is less likely that the sweep its self cause any issues otherwise all the sweeps will have issues. If you cannot duplicate the error, it will be more difficult for us. Probably you can delete the current sweep object and then add a new one again, and test if it works.
Please check the warning message and then check what cause it as I cannot read the warning message from your screeshot.
