Ren
Is this the first time that you use the import CHEMKIN Mechanism feature?
Please perform the following test:
  1. Select methane-air under Mixture Material in the Species Model dialog box, then click on the "Ok" button.
  2. Set up the case with some sensible boundary conditions
  3. Initialise the flow and calculate for a few iterations to see if you are able to do this
