July 19, 2023 at 12:39 pm
Hello Vivek,
Is this the first time you're using 23R1? Can you try resetting app data and let us know if that didn't help.
- Go to the Start Menu and open %temp% folder. Search for ‘.ansys’ folder and rename it to ‘.ansys.old’ then launch the application.
- Open a file explorer and type %appdata% in the address bar.
Locate the Ansys folder --> select version (V231) and rename it to V231.old
Also did you check Gary's link to another discussion. I would recommend you to start a new post, instead of following on old threads.
Nanda.
