Johannes Reinken
ok, I tried that and it kind of works for showing the plot on the screen. (although it is not very convenient, as the forces in the horizontal beams at the upper and lower border are higher than the ones in the middle and it takes a lot of work to select all the beams and scale them with different values. especially as i have to do that for multiple plots and each time have to select the groups to scale by hand..)
in addition the /show,png,,0 only saves the last plot, so i don’t get the overlaying plots there..
Do you have another idea? There is no command to just scale the width of the line, is there?
