To perform a decay test with Ansys AQWA, you can use the Hydrodynamic Response Module. The decay test is a time history response analysis. It is normal to choose Irregular Wave Response With Slow Drift (Irregular Wave) and then provide an initial position to provide the offset of the particular DOF that you require the decay test for. Candy Crush
