NickFL
Look under %AppData% (yes A and D must be big). There should be a folder Ansys in there. Open this folder and then see a folder named v221 or whatever version number you are using. Delete or rename this directory.
Another thing. Are you using the same version from the student model to the academic? You cannot (easily) go backwards.
