July 20, 2023 at 2:57 pm
Thank you for the suggestion. I tried doing that. But, I am seeing another error upon exporting the parts with issue (the shaft and the rotor core in my case) and importing those back into the model. I have attached the error below which says: Model moving objects should be completely within the band. I did not make any modifications to the Motion Setup and the moving band, just deleted the old rotor core and shaft and imported the rotor core and shaft from the .x_b file.
Can you please help me out with this ?
