Andreas Koutras
Hello Fady,
You may use multiple *DAMPING_FREQUENCY_RANGE_DEFORM keywords only if each of these keywords is applied to a unique part set. If more than one *DAMPING_FREQUENCY_RANGE_DEFORM keywords are defined for a part, then the following Warning is produced. You can verify this with an example.
