Thank you for your suggestion.
I had also thought of this idea, only that it failed because I can only define the gravity at the main axes. Proportionally over cosine and sine is therefore not possible, even if I inserted an additional cylindrical coordinate system. With the solution combinations the area of the phase angle is grayed out.
