I thought I solved the problem by clearing the folder: C:\Users\XXXX\AppData\Roaming\Ansys but problem occured again and again after clear.
The real cause of the problem was low disc space. While the program is evaluating the results it needs more data space. Clearing Roaming only temporarily solve the problem because it freed up more disk space.
Thanks for help.
