Thank you for the response. I have decided to rebuild the model using S-ALE and am now running into different issues. Currently, my model consists only of air and water elements with no motion. I set it up this way so I could get the S-ALE portion out of the way first. I am currently running into errors on lines 29, 31, 50, 57, 59, 62, 64. I have attached the file with the reduced input. Any help would be greatly appreciated. Thank you.
$# LS-DYNA Keyword file created by LS-PrePost(R) V4.9.12-16Dec2022
$# Created on Jul-24-2023 (09:09:30)
*KEYWORD
*TITLE
$# titlef
LS-DYNA keyword deck by LS-PrePost
*CONTROL_ALE
$# dct nadv meth afac bfac cfac dfac efacf
1 1 1 0.0 0.0 0.0 0.0 0.0
$# start end aafac vfact prit ebc pref nsidebcf
0.01.00000E20 1.01.00000E-6 0 0 0.0
$# ncpl nbkt imascl checkr beamin mmgpref pdifmx dtmufacf
1 50 0 0.0 0.0 0 0.0 0.0
$# optimpp ialedr bndflx minmas
0 0 01.00000E-5
*CONTROL_TERMINATION
$# endtim endcyc dtmin endeng endmas nosol
15.0 0 0.0 0.01.000000E8 0
*CONTROL_TIMESTEP
$# dtinit tssfac isdo tslimt dt2ms lctm erode ms1stf
0.0 0.6 0 0.0 0.0 0 0 0
*DATABASE_BINARY_D3PLOT
$# dt lcdt beam npltc psetid
0.01 0 0 0 0
$# ioopt rate cutoff window type pset
0 0 0
*ALE_STRUCTURED_MESH
$# mshid dpid nbid ebid unused unused unused tdeathf
1 10000 500001 500001 1.00000E16
$# cpidx cpidy cpidz nid0 lcsid
1001 1002 1003
*ALE_STRUCTURED_MESH_CONTROL_POINTS
$# cpid unused icase sfo unused offo
1001 0 1.0 0.0
$# n x ratio
1 -0.1 0.0
222 11.0 0.0
1002 0 1.0 0.0
$# n x ratio
1 0.0 0.0
13 0.65 0.0
1003 0 1.0 0.0
$# n x ratio
1 0.0 0.0
24 1.2 0.0
*ALE_STRUCTURED_MULTI-MATERIAL_GROUP
$#ammg_name mid eosid unused unused unused unused pref
Water 1 1 0.0
Air 2 0 0.0
*ALE_STRUCTURED_MESH_VOLUME_FILLING
$# mshid unused ammgto unused nsample unused unused- vidf
1 Air 3 0
$# geom in/out e1 e2 e3 e4 e5
ALL 0
1 Water 3 0
$# geom in/out boxid e2 e3 e4 e5
BOXCOR 0 1
*MAT_NULL_TITLE
Water
$# mid ro pc mu terod cerod ym prf
1 998.21 -10.08.68400E-4 0.0 0.0 0.0 0.0
*MAT_VACUUM_TITLE
Air
$# mid rho
21.0000E-12
*DEFINE_BOX_LOCAL_TITLE
Water Box
$# boxid xmn xmx ymn ymx zmn zmx
1 -0.1 11.0 0.0 0.65 0.0 0.6
$# xx yx zx xv yv zv
0.0 0.0 0.0 0.0 0.0 0.0
$# cx cy cz
0.0 0.0 0.0
*EOS_MURNAGHAN_TITLE
Water EOS
$# eosid gamma k0 v0
1 7.0 150000.0 0.0
*END
