Daniel Shaw
Andrei:
If you are using the Mechanical Fatigue Tool (FT) you should not use an elastic-plastic material model.  The FT performs StrainLife (EN) fatigue using elastically calculated stresses and the Neuber elastic-plastic correction method.  It does not use FE calculated plastic strains.
