Nanda Veralla
Hello Gianluca,
Yes, you are correct. You can retrieve them by using user defined results.
In case you are unaware, Ansys has another feature called "bolt thread contact" which models a simple cylindrical face into threads numerically. This feature is available under contacts-->geometry modification. This might be the best approach for calculating MoS calculations accurately.
Geometric Modification (ansys.com)
3.8. Geometry Correction for Contact and Target Surfaces (ansys.com)
