You can run Workbench in batch mode via python script, started from SC. These are seperate applications, so there is no way other than initiating the Workbench application to run a script file, but this can definitely be a solution.
You may also want to look at Ansys Discovery, which can run structural simulations and has very similar geometry creation methods/API as SC.
