July 24, 2023 at 3:17 pm
The B-H curves are created for simulation under no temperature modification. Meaning that data is taken from multiple references such as material datasheets and a B - H curve is created, but a change in temperature does not change this B-H curve. In order to make the material properties temperature dependent, one would have to add a thermal modifier on the material properties. This is done by checkin the "Thermal Modifier" check box on the material properties. The thermal modifier could be a simple gain or a temperature dependent dataset.
