There is no spherical coordinate system available in external data.
Possibly you can export the current mesh node locations, by solving an all-fixed support and no load (using a blank command snippet) static structural analysis and then use Excel to calculate the radius of each point and use a formula to update data based on the radius and then bring in this data in via external data.
-Aniket
