Kevin,
On the Result tab is the Display Scale Factor. I think you have this turned up so high that the bottom skin is poking up through the top skin.  Try setting it to 1.0 (True Scale) value.
Plot directional deformation along the Z axis so you can see different colors when the panel moves up vs down. This is more informative than total deformation.
