Caleb Wood
****************************************UPDATE************************************
I added all the required keywords needed to make my model function as intended, and now there is a total of 7 errors present, shown below:
 Beginning of keyword reader                                   07/25/23 14:17:48
 *** Error 10246 (KEY+246)
     line contains improperly formatted data
      reading *ALE_STRUCTURED_MESH cards
          At line# 131 of file
 F:\Caleb\LS-DYNA\S-ALE\S-ALE_Rebuild.k
 ALL                0
          At line# 136 of file
 BOXCOR             0         1
 *** Error 10450 (KEY+450)
     in keyword command:
*ALE_STRUCTURED_FSI
          At line# 137 of file
 *** Warning 10435 (KEY+435)
     lines being skipped - See messag or d3hsp files
 *** Error 11021 (KEY+1021)
       The # 2 ALE_STRUCTURED_MESH card has a starting
         node id 2, smaller than the maximum
         node id 1077350
 *** Error 11026 (KEY+1026)
       The # 3 ALE_STRUCTURED_MESH card has a
         duplicate part id 0 already used by the 5th part.
       The # 3 ALE_STRUCTURED_MESH card has a starting
         node id 1, smaller than the maximum
         node id 1077350
 *** Error 10176 (KEY+176)
     repeated part ID 0
 *** Error 10133 (KEY+133)
     input data failed with: 7 errors
 E r r o r   t e r m i n a t i o n                             07/25/23 14:18:04
Any help with these errors is greatly appreciated. Also, the .k file is saved as version R14 and is attached.
*********************************************************** .k FILE *******************************************************
$# LS-DYNA Keyword file created by LS-PrePost(R) V4.9.12-16Dec2022
$# Created on Jul-25-2023 (14:15:14)
*KEYWORD
*TITLE
$#        title
LS-DYNA keyword deck by LS-PrePost
*CONTROL_ALE
$#     dct      nadv      meth      afac      bfac      cfac      dfac      efac
         1         1         2       0.0       0.0       0.0       0.0       0.0
$#   start       end     aafac     vfact      prit       ebc      pref   nsidebc
       0.01.00000E20       1.01.00000E-6         0         0       0.0
$#    ncpl      nbkt    imascl    checkr    beamin   mmgpref    pdifmx   dtmufac
         1        50         0       0.0       0.0         0       0.0       0.0
$# optimpp    ialedr    bndflx    minmas
         0         0         01.00000E-5
*CONTROL_TERMINATION
$#  endtim    endcyc     dtmin    endeng    endmas     nosol
      15.0         0       0.0       0.01.000000E8         0
*CONTROL_TIMESTEP
$#  dtinit    tssfac      isdo    tslimt     dt2ms      lctm     erode     ms1st
       0.0       0.6         0       0.0       0.0         0         0         0
*CONTROL_UNITS
$#  length      time      mass      temp
m         sec       kg        k
*DATABASE_BINARY_D3PLOT
$#      dt      lcdt      beam     npltc    psetid
      0.01         0         0         0         0
$#   ioopt      rate    cutoff    window      type      pset
         0                                       0         0
*BOUNDARY_PRESCRIBED_MOTION_SET_ID
$#      id                                                               heading
         0Piston Motion
$#    nsid       dof       vad      lcid        sf       vid     death     birth
         1         1         2         1       1.0         01.00000E28       0.0
*LOAD_BODY_GENERALIZED_SET_PART
$#    psid        n2      lcid    drlcid        xc        yc        zc
         1         0         2         0       0.0       0.0       0.0
$#      ax        ay        az       omx       omy       omz       cid    angtyp
       0.0       0.0      9.81       0.0       0.0       0.0          CENT
*PART
$#        title
Water
$#     pid     secid       mid     eosid      hgid      grav    adpopt      tmid
         2         2         2         2         2         0         0         0
*SECTION_SOLID_TITLE
Water
$#   secid    elform       aet    unused    unused    unused    cohoff   gaskeit
         2        11         0                                     0.0       0.0
*MAT_NULL_TITLE
Water
$#     mid        ro        pc        mu     terod     cerod        ym        pr
         2     998.0     -10.0       0.0       0.0       0.0       0.0       0.0
*EOS_MURNAGHAN_TITLE
Water EOS
$#   eosid     gamma        k0        v0
         2       7.0  150000.0       0.0
*HOURGLASS_TITLE
Water
$#    hgid       ihq        qm       ibq        q1        q2    qb/vdc        qw
         2         11.00000E-6         0       1.5      0.061.00000E-61.00000E-6
*PART
$#        title
Air
         3         3         3         0         3         0         0         0
Air
         3        11         0                                     0.0       0.0
*MAT_VACUUM_TITLE
Air
$#     mid       rho
         31.0000E-12
*HOURGLASS_TITLE
Air
         3         11.00000E-6         0       1.5      0.061.00000E-61.00000E-6
*PART
$#        title
Piston
         4         4         4         0         0         0         0         0
*SECTION_SHELL_TITLE
Piston
$#   secid    elform      shrf       nip     propt   qr/irid     icomp     setyp
         4        16       1.0         2       1.0         0         0         1
$#      t1        t2        t3        t4      nloc     marea      idof    edgset
       0.5       0.5       0.5       0.5       0.0       0.0       0.0         0
*MAT_RIGID_TITLE
Piston
$#     mid        ro         e        pr         n    couple         m     alias
         4     100.0   20000.0      0.25       0.0       0.0       0.0
$#     cmo      con1      con2
       1.0         5         7
$#lco or a1        a2        a3        v1        v2        v3
       0.0
$#   mshid      dpid      nbid      ebid    unused    unused    unused    tdeath
         1         1   1000001   1000001
$#   cpidx     cpidy     cpidz      nid0     lcsid
      1001      1002      1003
*ALE_STRUCTURED_MESH_CONTROL_POINTS
$#    cpid    unused     icase       sfo    unused      offo
      1001                   0       1.0                 0.0
$#                 n                   x               ratio
                   1                 0.0                 0.0
                 221                11.0                 0.0
      1002                   0       1.0                 0.0
$#                 n                   x               ratio
                   1                 0.0                 0.0
                  14                0.65                 0.0
      1003                   0       1.0                 0.0
$#                 n                   x               ratio
                   1                 0.0                 0.0
                  25                 1.2                 0.0
*ALE_ESSENTIAL_BOUNDARY
$#      id    idtype    ictype     iexcl
         1         1         1         0
*ALE_MULTI-MATERIAL_GROUP
$#     sid    idtype
         2         1
         3         1
*ALE_STRUCTURED_MESH_VOLUME_FILLING
$#   mshid    unused    ammgto    unused   nsample    unused   unused-       vid
         1          2                            3                             0
$#    geom    in/out        e1        e2        e3        e4        e5
ALL                0
         1          1                            3                             0
$#    geom    in/out     boxid        e2        e3        e4        e5
BOXCOR             0         1
*ALE_STRUCTURED_FSI
$# lstrsid    alesid  lstrstyp   alestyp         -         -         -     mcoup
         4         2         1         1                                    -102
$#   start       end      pfac      fric         -      flip
       0.01.00000E10       0.1       0.0                   0
*DEFINE_BOX_LOCAL_TITLE
Water Box
$#   boxid       xmn       xmx       ymn       ymx       zmn       zmx
         1       0.0      11.0       0.0      0.65       0.0       0.6
$#      xx        yx        zx        xv        yv        zv
$#      cx        cy        cz
       0.0       0.0       0.0
*DEFINE_CURVE_TITLE
Piston Motion
$#    lcid      sidr       sfa       sfo      offa      offo    dattyp     lcint
         1         0      0.56      0.23       0.0       0.0         0         0
$#                a1                  o1
                 0.0                 0.0
                 1.0                 1.0
                 2.0                 0.0
                 3.0                 1.0
                 4.0                 0.0
                 5.0                 1.0
                 6.0                 0.0
                 7.0                 1.0
                 8.0                 0.0
                 9.0                 1.0
                10.0                 0.0
                11.0                 1.0
                12.0                 0.0
                13.0                 1.0
                14.0                 0.0
                15.0                 1.0
                16.0                 0.0
                17.0                 1.0
                18.0                 0.0
                19.0                 1.0
                20.0                 0.0
                21.0                 1.0
                22.0                 0.0
                23.0                 1.0
                24.0                 0.0
                25.0                 1.0
                26.0                 0.0
                27.0                 1.0
                28.0                 0.0
                29.0                 1.0
                30.0                 0.0
*DEFINE_CURVE_TITLE
Gravity
         2         0       1.0       1.0       0.0       0.0         0         0
$#                a1                  o1
                 0.0                 1.0
               100.0                 1.0
*ELEMENT_SHELL
$#   eid     pid      n1      n2      n3      n4      n5      n6      n7      n8
       1       4      15       1       2      16       0       0       0       0
       2       4      16       2       3      17       0       0       0       0
       3       4      17       3       4      18       0       0       0       0
       4       4      18       4       5      19       0       0       0       0
       5       4      19       5       6      20       0       0       0       0
       6       4      20       6       7      21       0       0       0       0
       7       4      21       7       8      22       0       0       0       0
       8       4      22       8       9      23       0       0       0       0
       9       4      23       9      10      24       0       0       0       0
      10       4      24      10      11      25       0       0       0       0
      11       4      25      11      12      26       0       0       0       0
      12       4      26      12      13      27       0       0       0       0
      13       4      27      13      14      28       0       0       0       0
      14       4      29      15      16      30       0       0       0       0
      15       4      30      16      17      31       0       0       0       0
      16       4      31      17      18      32       0       0       0       0
      17       4      32      18      19      33       0       0       0       0
      18       4      33      19      20      34       0       0       0       0
      19       4      34      20      21      35       0       0       0       0
      20       4      35      21      22      36       0       0       0       0
      21       4      36      22      23      37       0       0       0       0
      22       4      37      23      24      38       0       0       0       0
      23       4      38      24      25      39       0       0       0       0
      24       4      39      25      26      40       0       0       0       0
      25       4      40      26      27      41       0       0       0       0
      26       4      41      27      28      42       0       0       0       0
      27       4      43      29      30      44       0       0       0       0
      28       4      44      30      31      45       0       0       0       0
      29       4      45      31      32      46       0       0       0       0
      30       4      46      32      33      47       0       0       0       0
      31       4      47      33      34      48       0       0       0       0
      32       4      48      34      35      49       0       0       0       0
      33       4      49      35      36      50       0       0       0       0
      34       4      50      36      37      51       0       0       0       0
      35       4      51      37      38      52       0       0       0       0
      36       4      52      38      39      53       0       0       0       0
      37       4      53      39      40      54       0       0       0       0
      38       4      54      40      41      55       0       0       0       0
      39       4      55      41      42      56       0       0       0       0
      40       4      57      43      44      58       0       0       0       0
      41       4      58      44      45      59       0       0       0       0
      42       4      59      45      46      60       0       0       0       0
      43       4      60      46      47      61       0       0       0       0
      44       4      61      47      48      62       0       0       0       0
      45       4      62      48      49      63       0       0       0       0
      46       4      63      49      50      64       0       0       0       0
      47       4      64      50      51      65       0       0       0       0
      48       4      65      51      52      66       0       0       0       0
      49       4      66      52      53      67       0       0       0       0
      50       4      67      53      54      68       0       0       0       0
      51       4      68      54      55      69       0       0       0       0
      52       4      69      55      56      70       0       0       0       0
      53       4      71      57      58      72       0       0       0       0
      54       4      72      58      59      73       0       0       0       0
      55       4      73      59      60      74       0       0       0       0
      56       4      74      60      61      75       0       0       0       0
      57       4      75      61      62      76       0       0       0       0
      58       4      76      62      63      77       0       0       0       0
      59       4      77      63      64      78       0       0       0       0
      60       4      78      64      65      79       0       0       0       0
      61       4      79      65      66      80       0       0       0       0
      62       4      80      66      67      81       0       0       0       0
      63       4      81      67      68      82       0       0       0       0
      64       4      82      68      69      83       0       0       0       0
      65       4      83      69      70      84       0       0       0       0
      66       4      85      71      72      86       0       0       0       0
      67       4      86      72      73      87       0       0       0       0
      68       4      87      73      74      88       0       0       0       0
      69       4      88      74      75      89       0       0       0       0
      70       4      89      75      76      90       0       0       0       0
      71       4      90      76      77      91       0       0       0       0
      72       4      91      77      78      92       0       0       0       0
      73       4      92      78      79      93       0       0       0       0
      74       4      93      79      80      94       0       0       0       0
      75       4      94      80      81      95       0       0       0       0
      76       4      95      81      82      96       0       0       0       0
      77       4      96      82      83      97       0       0       0       0
      78       4      97      83      84      98       0       0       0       0
      79       4      99      85      86     100       0       0       0       0
      80       4     100      86      87     101       0       0       0       0
      81       4     101      87      88     102       0       0       0       0
      82       4     102      88      89     103       0       0       0       0
      83       4     103      89      90     104       0       0       0       0
      84       4     104      90      91     105       0       0       0       0
      85       4     105      91      92     106       0       0       0       0
      86       4     106      92      93     107       0       0       0       0
      87       4     107      93      94     108       0       0       0       0
      88       4     108      94      95     109       0       0       0       0
      89       4     109      95      96     110       0       0       0       0
      90       4     110      96      97     111       0       0       0       0
      91       4     111      97      98     112       0       0       0       0
      92       4     113      99     100     114       0       0       0       0
      93       4     114     100     101     115       0       0       0       0
      94       4     115     101     102     116       0       0       0       0
      95       4     116     102     103     117       0       0       0       0
      96       4     117     103     104     118       0       0       0       0
      97       4     118     104     105     119       0       0       0       0
      98       4     119     105     106     120       0       0       0       0
      99       4     120     106     107     121       0       0       0       0
     100       4     121     107     108     122       0       0       0       0
     101       4     122     108     109     123       0       0       0       0
     102       4     123     109     110     124       0       0       0       0
     103       4     124     110     111     125       0       0       0       0
     104       4     125     111     112     126       0       0       0       0
     105       4     127     113     114     128       0       0       0       0
     106       4     128     114     115     129       0       0       0       0
     107       4     129     115     116     130       0       0       0       0
     108       4     130     116     117     131       0       0       0       0
     109       4     131     117     118     132       0       0       0       0
     110       4     132     118     119     133       0       0       0       0
     111       4     133     119     120     134       0       0       0       0
     112       4     134     120     121     135       0       0       0       0
     113       4     135     121     122     136       0       0       0       0
     114       4     136     122     123     137       0       0       0       0
     115       4     137     123     124     138       0       0       0       0
     116       4     138     124     125     139       0       0       0       0
     117       4     139     125     126     140       0       0       0       0
     118       4     141     127     128     142       0       0       0       0
     119       4     142     128     129     143       0       0       0       0
     120       4     143     129     130     144       0       0       0       0
     121       4     144     130     131     145       0       0       0       0
     122       4     145     131     132     146       0       0       0       0
     123       4     146     132     133     147       0       0       0       0
     124       4     147     133     134     148       0       0       0       0
     125       4     148     134     135     149       0       0       0       0
     126       4     149     135     136     150       0       0       0       0
     127       4     150     136     137     151       0       0       0       0
     128       4     151     137     138     152       0       0       0       0
     129       4     152     138     139     153       0       0       0       0
     130       4     153     139     140     154       0       0       0       0
     131       4     155     141     142     156       0       0       0       0
     132       4     156     142     143     157       0       0       0       0
     133       4     157     143     144     158       0       0       0       0
     134       4     158     144     145     159       0       0       0       0
     135       4     159     145     146     160       0       0       0       0
     136       4     160     146     147     161       0       0       0       0
     137       4     161     147     148     162       0       0       0       0
     138       4     162     148     149     163       0       0       0       0
     139       4     163     149     150     164       0       0       0       0
     140       4     164     150     151     165       0       0       0       0
     141       4     165     151     152     166       0       0       0       0
     142       4     166     152     153     167       0       0       0       0
     143       4     167     153     154     168       0       0       0       0
     144       4     169     155     156     170       0       0       0       0
     145       4     170     156     157     171       0       0       0       0
     146       4     171     157     158     172       0       0       0       0
     147       4     172     158     159     173       0       0       0       0
     148       4     173     159     160     174       0       0       0       0
     149       4     174     160     161     175       0       0       0       0
     150       4     175     161     162     176       0       0       0       0
     151       4     176     162     163     177       0       0       0       0
     152       4     177     163     164     178       0       0       0       0
     153       4     178     164     165     179       0       0       0       0
     154       4     179     165     166     180       0       0       0       0
     155       4     180     166     167     181       0       0       0       0
     156       4     181     167     168     182       0       0       0       0
     157       4     183     169     170     184       0       0       0       0
     158       4     184     170     171     185       0       0       0       0
     159       4     185     171     172     186       0       0       0       0
     160       4     186     172     173     187       0       0       0       0
     161       4     187     173     174     188       0       0       0       0
     162       4     188     174     175     189       0       0       0       0
     163       4     189     175     176     190       0       0       0       0
     164       4     190     176     177     191       0       0       0       0
     165       4     191     177     178     192       0       0       0       0
     166       4     192     178     179     193       0       0       0       0
     167       4     193     179     180     194       0       0       0       0
     168       4     194     180     181     195       0       0       0       0
     169       4     195     181     182     196       0       0       0       0
     170       4     197     183     184     198       0       0       0       0
     171       4     198     184     185     199       0       0       0       0
     172       4     199     185     186     200       0       0       0       0
     173       4     200     186     187     201       0       0       0       0
     174       4     201     187     188     202       0       0       0       0
     175       4     202     188     189     203       0       0       0       0
     176       4     203     189     190     204       0       0       0       0
     177       4     204     190     191     205       0       0       0       0
     178       4     205     191     192     206       0       0       0       0
     179       4     206     192     193     207       0       0       0       0
     180       4     207     193     194     208       0       0       0       0
     181       4     208     194     195     209       0       0       0       0
     182       4     209     195     196     210       0       0       0       0
     183       4     211     197     198     212       0       0       0       0
     184       4     212     198     199     213       0       0       0       0
     185       4     213     199     200     214       0       0       0       0
     186       4     214     200     201     215       0       0       0       0
     187       4     215     201     202     216       0       0       0       0
     188       4     216     202     203     217       0       0       0       0
     189       4     217     203     204     218       0       0       0       0
     190       4     218     204     205     219       0       0       0       0
     191       4     219     205     206     220       0       0       0       0
     192       4     220     206     207     221       0       0       0       0
     193       4     221     207     208     222       0       0       0       0
     194       4     222     208     209     223       0       0       0       0
     195       4     223     209     210     224       0       0       0       0
     196       4     225     211     212     226       0       0       0       0
     197       4     226     212     213     227       0       0       0       0
     198       4     227     213     214     228       0       0       0       0
     199       4     228     214     215     229       0       0       0       0
     200       4     229     215     216     230       0       0       0       0
     201       4     230     216     217     231       0       0       0       0
     202       4     231     217     218     232       0       0       0       0
     203       4     232     218     219     233       0       0       0       0
     204       4     233     219     220     234       0       0       0       0
     205       4     234     220     221     235       0       0       0       0
     206       4     235     221     222     236       0       0       0       0
     207       4     236     222     223     237       0       0       0       0
     208       4     237     223     224     238       0       0       0       0
     209       4     239     225     226     240       0       0       0       0
     210       4     240     226     227     241       0       0       0       0
     211       4     241     227     228     242       0       0       0       0
     212       4     242     228     229     243       0       0       0       0
     213       4     243     229     230     244       0       0       0       0
     214       4     244     230     231     245       0       0       0       0
     215       4     245     231     232     246       0       0       0       0
     216       4     246     232     233     247       0       0       0       0
     217       4     247     233     234     248       0       0       0       0
     218       4     248     234     235     249       0       0       0       0
     219       4     249     235     236     250       0       0       0       0
     220       4     250     236     237     251       0       0       0       0
     221       4     251     237     238     252       0       0       0       0
     222       4     253     239     240     254       0       0       0       0
     223       4     254     240     241     255       0       0       0       0
     224       4     255     241     242     256       0       0       0       0
     225       4     256     242     243     257       0       0       0       0
     226       4     257     243     244     258       0       0       0       0
     227       4     258     244     245     259       0       0       0       0
     228       4     259     245     246     260       0       0       0       0
     229       4     260     246     247     261       0       0       0       0
     230       4     261     247     248     262       0       0       0       0
     231       4     262     248     249     263       0       0       0       0
     232       4     263     249     250     264       0       0       0       0
     233       4     264     250     251     265       0       0       0       0
     234       4     265     251     252     266       0       0       0       0
     235       4     267     253     254     268       0       0       0       0
     236       4     268     254     255     269       0       0       0       0
     237       4     269     255     256     270       0       0       0       0
     238       4     270     256     257     271       0       0       0       0
     239       4     271     257     258     272       0       0       0       0
     240       4     272     258     259     273       0       0       0       0
     241       4     273     259     260     274       0       0       0       0
     242       4     274     260     261     275       0       0       0       0
     243       4     275     261     262     276       0       0       0       0
     244       4     276     262     263     277       0       0       0       0
     245       4     277     263     264     278       0       0       0       0
     246       4     278     264     265     279       0       0       0       0
     247       4     279     265     266     280       0       0       0       0
     248       4     281     267     268     282       0       0       0       0
     249       4     282     268     269     283       0       0       0       0
     250       4     283     269     270     284       0       0       0       0
     251       4     284     270     271     285       0       0       0       0
     252       4     285     271     272     286       0       0       0       0
     253       4     286     272     273     287       0       0       0       0
     254       4     287     273     274     288       0       0       0       0
     255       4     288     274     275     289       0       0       0       0
     256       4     289     275     276     290       0       0       0       0
     257       4     290     276     277     291       0       0       0       0
     258       4     291     277     278     292       0       0       0       0
     259       4     292     278     279     293       0       0       0       0
     260       4     293     279     280     294       0       0       0       0
     261       4     295     281     282     296       0       0       0       0
     262       4     296     282     283     297       0       0       0       0
     263       4     297     283     284     298       0       0       0       0
     264       4     298     284     285     299       0       0       0       0
     265       4     299     285     286     300       0       0       0       0
     266       4     300     286     287     301       0       0       0       0
     267       4     301     287     288     302       0       0       0       0
     268       4     302     288     289     303       0       0       0       0
     269       4     303     289     290     304       0       0       0       0
     270       4     304     290     291     305       0       0       0       0
     271       4     305     291     292     306       0       0       0       0
     272       4     306     292     293     307       0       0       0       0
     273       4     307     293     294     308       0       0       0       0
     274       4     309     295     296     310       0       0       0       0
     275       4     310     296     297     311       0       0       0       0
     276       4     311     297     298     312       0       0       0       0
     277       4     312     298     299     313       0       0       0       0
     278       4     313     299     300     314       0       0       0       0
     279       4     314     300     301     315       0       0       0       0
     280       4     315     301     302     316       0       0       0       0
     281       4     316     302     303     317       0       0       0       0
     282       4     317     303     304     318       0       0       0       0
     283       4     318     304     305     319       0       0       0       0
     284       4     319     305     306     320       0       0       0       0
     285       4     320     306     307     321       0       0       0       0
     286       4     321     307     308     322       0       0       0       0
     287       4     323     309     310     324       0       0       0       0
     288       4     324     310     311     325       0       0       0       0
     289       4     325     311     312     326       0       0       0       0
     290       4     326     312     313     327       0       0       0       0
     291       4     327     313     314     328       0       0       0       0
     292       4     328     314     315     329       0       0       0       0
     293       4     329     315     316     330       0       0       0       0
     294       4     330     316     317     331       0       0       0       0
     295       4     331     317     318     332       0       0       0       0
     296       4     332     318     319     333       0       0       0       0
     297       4     333     319     320     334       0       0       0       0
     298       4     334     320     321     335       0       0       0       0
     299       4     335     321     322     336       0       0       0       0
     300       4     337     323     324     338       0       0       0       0
     301       4     338     324     325     339       0       0       0       0
     302       4     339     325     326     340       0       0       0       0
     303       4     340     326     327     341       0       0       0       0
     304       4     341     327     328     342       0       0       0       0
     305       4     342     328     329     343       0       0       0       0
     306       4     343     329     330     344       0       0       0       0
     307       4     344     330     331     345       0       0       0       0
     308       4     345     331     332     346       0       0       0       0
     309       4     346     332     333     347       0       0       0       0
     310       4     347     333     334     348       0       0       0       0
     311       4     348     334     335     349       0       0       0       0
     312       4     349     335     336     350       0       0       0       0
*NODE
$#   nid               x               y               z      tc      rc
       1             0.0             0.0             0.0       0       0
       2             0.0            0.05             0.0       0       0
       3             0.0             0.1             0.0       0       0
       4             0.0            0.15             0.0       0       0
       5             0.0             0.2             0.0       0       0
       6             0.0            0.25             0.0       0       0
       7             0.0             0.3             0.0       0       0
       8             0.0            0.35             0.0       0       0
       9             0.0             0.4             0.0       0       0
      10             0.0            0.45             0.0       0       0
      11             0.0             0.5             0.0       0       0
      12             0.0            0.55             0.0       0       0
      13             0.0             0.6             0.0       0       0
      14             0.0            0.65             0.0       0       0
      15             0.0             0.0            0.05       0       0
      16             0.0            0.05            0.05       0       0
      17             0.0             0.1            0.05       0       0
      18             0.0            0.15            0.05       0       0
      19             0.0             0.2            0.05       0       0
      20             0.0            0.25            0.05       0       0
      21             0.0             0.3            0.05       0       0
      22             0.0            0.35            0.05       0       0
      23             0.0             0.4            0.05       0       0
      24             0.0            0.45            0.05       0       0
      25             0.0             0.5            0.05       0       0
      26             0.0            0.55            0.05       0       0
      27             0.0             0.6            0.05       0       0
      28             0.0            0.65            0.05       0       0
      29             0.0             0.0             0.1       0       0
      30             0.0            0.05             0.1       0       0
      31             0.0             0.1             0.1       0       0
      32             0.0            0.15             0.1       0       0
      33             0.0             0.2             0.1       0       0
      34             0.0            0.25             0.1       0       0
      35             0.0             0.3             0.1       0       0
      36             0.0            0.35             0.1       0       0
      37             0.0             0.4             0.1       0       0
      38             0.0            0.45             0.1       0       0
      39             0.0             0.5             0.1       0       0
      40             0.0            0.55             0.1       0       0
      41             0.0             0.6             0.1       0       0
      42             0.0            0.65             0.1       0       0
      43             0.0             0.0            0.15       0       0
      44             0.0            0.05            0.15       0       0
      45             0.0             0.1            0.15       0       0
      46             0.0            0.15            0.15       0       0
      47             0.0             0.2            0.15       0       0
      48             0.0            0.25            0.15       0       0
      49             0.0             0.3            0.15       0       0
      50             0.0            0.35            0.15       0       0
      51             0.0             0.4            0.15       0       0
      52             0.0            0.45            0.15       0       0
      53             0.0             0.5            0.15       0       0
      54             0.0            0.55            0.15       0       0
      55             0.0             0.6            0.15       0       0
      56             0.0            0.65            0.15       0       0
      57             0.0             0.0             0.2       0       0
      58             0.0            0.05             0.2       0       0
      59             0.0             0.1             0.2       0       0
      60             0.0            0.15             0.2       0       0
      61             0.0             0.2             0.2       0       0
      62             0.0            0.25             0.2       0       0
      63             0.0             0.3             0.2       0       0
      64             0.0            0.35             0.2       0       0
      65             0.0             0.4             0.2       0       0
      66             0.0            0.45             0.2       0       0
      67             0.0             0.5             0.2       0       0
      68             0.0            0.55             0.2       0       0
      69             0.0             0.6             0.2       0       0
      70             0.0            0.65             0.2       0       0
      71             0.0             0.0            0.25       0       0
      72             0.0            0.05            0.25       0       0
      73             0.0             0.1            0.25       0       0
      74             0.0            0.15            0.25       0       0
      75             0.0             0.2            0.25       0       0
      76             0.0            0.25            0.25       0       0
      77             0.0             0.3            0.25       0       0
      78             0.0            0.35            0.25       0       0
      79             0.0             0.4            0.25       0       0
      80             0.0            0.45            0.25       0       0
      81             0.0             0.5            0.25       0       0
      82             0.0            0.55            0.25       0       0
      83             0.0             0.6            0.25       0       0
      84             0.0            0.65            0.25       0       0
      85             0.0             0.0             0.3       0       0
      86             0.0            0.05             0.3       0       0
      87             0.0             0.1             0.3       0       0
      88             0.0            0.15             0.3       0       0
      89             0.0             0.2             0.3       0       0
      90             0.0            0.25             0.3       0       0
      91             0.0             0.3             0.3       0       0
      92             0.0            0.35             0.3       0       0
      93             0.0             0.4             0.3       0       0
      94             0.0            0.45             0.3       0       0
      95             0.0             0.5             0.3       0       0
      96             0.0            0.55             0.3       0       0
      97             0.0             0.6             0.3       0       0
      98             0.0            0.65             0.3       0       0
      99             0.0             0.0            0.35       0       0
     100             0.0            0.05       0.3500001       0       0
     101             0.0             0.1            0.35       0       0
     102             0.0            0.15            0.35       0       0
     103             0.0             0.2       0.3500001       0       0
     104             0.0            0.25            0.35       0       0
     105             0.0             0.3            0.35       0       0
     106             0.0            0.35            0.35       0       0
     107             0.0             0.4            0.35       0       0
     108             0.0            0.45       0.3500001       0       0
     109             0.0             0.5       0.3500001       0       0
     110             0.0            0.55            0.35       0       0
     111             0.0             0.6       0.3500001       0       0
     112             0.0            0.65            0.35       0       0
     113             0.0             0.0             0.4       0       0
     114             0.0            0.05             0.4       0       0
     115             0.0             0.1             0.4       0       0
     116             0.0            0.15             0.4       0       0
     117             0.0             0.2       0.4000001       0       0
     118             0.0            0.25             0.4       0       0
     119             0.0             0.3             0.4       0       0
     120             0.0            0.35             0.4       0       0
     121             0.0             0.4             0.4       0       0
     122             0.0            0.45             0.4       0       0
     123             0.0             0.5             0.4       0       0
     124             0.0            0.55             0.4       0       0
     125             0.0             0.6             0.4       0       0
     126             0.0            0.65             0.4       0       0
     127             0.0             0.0            0.45       0       0
     128             0.0            0.05            0.45       0       0
     129             0.0             0.1            0.45       0       0
     130             0.0            0.15            0.45       0       0
     131             0.0             0.2            0.45       0       0
     132             0.0            0.25            0.45       0       0
     133             0.0             0.3            0.45       0       0
     134             0.0            0.35            0.45       0       0
     135             0.0             0.4            0.45       0       0
     136             0.0            0.45            0.45       0       0
     137             0.0             0.5            0.45       0       0
     138             0.0            0.55            0.45       0       0
     139             0.0             0.6            0.45       0       0
     140             0.0            0.65            0.45       0       0
     141             0.0             0.0       0.5000001       0       0
     142             0.0            0.05             0.5       0       0
     143             0.0             0.1             0.5       0       0
     144             0.0            0.15       0.5000001       0       0
     145             0.0             0.2       0.5000001       0       0
     146             0.0            0.25             0.5       0       0
     147             0.0             0.3       0.5000001       0       0
     148             0.0            0.35       0.5000001       0       0
     149             0.0             0.4       0.5000001       0       0
     150             0.0            0.45             0.5       0       0
     151             0.0             0.5       0.5000001       0       0
     152             0.0            0.55             0.5       0       0
     153             0.0             0.6       0.5000001       0       0
     154             0.0            0.65       0.5000001       0       0
     155             0.0             0.0            0.55       0       0
     156             0.0            0.05            0.55       0       0
     157             0.0             0.1            0.55       0       0
     158             0.0            0.15            0.55       0       0
     159             0.0             0.2       0.5500001       0       0
     160             0.0            0.25            0.55       0       0
     161             0.0             0.3       0.5500001       0       0
     162             0.0            0.35            0.55       0       0
     163             0.0             0.4       0.5500001       0       0
     164             0.0            0.45       0.5500001       0       0
     165             0.0             0.5            0.55       0       0
     166             0.0            0.55            0.55       0       0
     167             0.0             0.6       0.5500001       0       0
     168             0.0            0.65            0.55       0       0
     169             0.0             0.0             0.6       0       0
     170             0.0            0.05             0.6       0       0
     171             0.0             0.1             0.6       0       0
     172             0.0            0.15             0.6       0       0
     173             0.0             0.2             0.6       0       0
     174             0.0            0.25             0.6       0       0
     175             0.0             0.3             0.6       0       0
     176             0.0            0.35             0.6       0       0
     177             0.0             0.4             0.6       0       0
     178             0.0            0.45             0.6       0       0
     179             0.0             0.5             0.6       0       0
     180             0.0            0.55             0.6       0       0
     181             0.0             0.6             0.6       0       0
     182             0.0            0.65             0.6       0       0
     183             0.0             0.0            0.65       0       0
     184             0.0            0.05            0.65       0       0
     185             0.0             0.1            0.65       0       0
     186             0.0            0.15            0.65       0       0
     187             0.0             0.2       0.6500001       0       0
     188             0.0            0.25            0.65       0       0
     189             0.0             0.3            0.65       0       0
     190             0.0            0.35            0.65       0       0
     191             0.0             0.4            0.65       0       0
     192             0.0            0.45            0.65       0       0
     193             0.0             0.5       0.6500001       0       0
     194             0.0            0.55            0.65       0       0
     195             0.0             0.6            0.65       0       0
     196             0.0            0.65            0.65       0       0
     197             0.0             0.0             0.7       0       0
     198             0.0            0.05       0.7000001       0       0
     199             0.0             0.1             0.7       0       0
     200             0.0            0.15             0.7       0       0
     201             0.0             0.2       0.7000001       0       0
     202             0.0            0.25             0.7       0       0
     203             0.0             0.3             0.7       0       0
     204             0.0            0.35             0.7       0       0
     205             0.0             0.4             0.7       0       0
     206             0.0            0.45       0.7000001       0       0
     207             0.0             0.5       0.7000001       0       0
     208             0.0            0.55             0.7       0       0
     209             0.0             0.6       0.7000001       0       0
     210             0.0            0.65             0.7       0       0
     211             0.0             0.0            0.75       0       0
     212             0.0            0.05            0.75       0       0
     213             0.0             0.1       0.7500001       0       0
     214             0.0            0.15            0.75       0       0
     215             0.0             0.2            0.75       0       0
     216             0.0            0.25            0.75       0       0
     217             0.0             0.3            0.75       0       0
     218             0.0            0.35            0.75       0       0
     219             0.0             0.4            0.75       0       0
     220             0.0            0.45            0.75       0       0
     221             0.0             0.5       0.7500001       0       0
     222             0.0            0.55       0.7500001       0       0
     223             0.0             0.6       0.7500001       0       0
     224             0.0            0.65            0.75       0       0
     225             0.0             0.0       0.8000001       0       0
     226             0.0            0.05       0.8000001       0       0
     227             0.0             0.1       0.8000001       0       0
     228             0.0            0.15             0.8       0       0
     229             0.0             0.2       0.8000001       0       0
     230             0.0            0.25       0.8000001       0       0
     231             0.0             0.3       0.8000001       0       0
     232             0.0            0.35       0.8000001       0       0
     233             0.0             0.4       0.8000001       0       0
     234             0.0            0.45       0.8000001       0       0
     235             0.0             0.5       0.8000001       0       0
     236             0.0            0.55       0.8000001       0       0
     237             0.0             0.6       0.8000001       0       0
     238             0.0            0.65       0.8000001       0       0
     239             0.0             0.0       0.8500001       0       0
     240             0.0            0.05       0.8500001       0       0
     241             0.0             0.1       0.8500001       0       0
     242             0.0            0.15       0.8500001       0       0
     243             0.0             0.2       0.8500001       0       0
     244             0.0            0.25            0.85       0       0
     245             0.0             0.3       0.8500001       0       0
     246             0.0            0.35       0.8500001       0       0
     247             0.0             0.4       0.8500001       0       0
     248             0.0            0.45       0.8500001       0       0
     249             0.0             0.5            0.85       0       0
     250             0.0            0.55       0.8500001       0       0
     251             0.0             0.6       0.8500001       0       0
     252             0.0            0.65       0.8500001       0       0
     253             0.0             0.0             0.9       0       0
     254             0.0            0.05       0.9000001       0       0
     255             0.0             0.1       0.9000001       0       0
     256             0.0            0.15             0.9       0       0
     257             0.0             0.2       0.9000001       0       0
     258             0.0            0.25             0.9       0       0
     259             0.0             0.3             0.9       0       0
     260             0.0            0.35             0.9       0       0
     261             0.0             0.4       0.9000001       0       0
     262             0.0            0.45             0.9       0       0
     263             0.0             0.5             0.9       0       0
     264             0.0            0.55       0.9000001       0       0
     265             0.0             0.6             0.9       0       0
     266             0.0            0.65             0.9       0       0
     267             0.0             0.0            0.95       0       0
     268             0.0            0.05            0.95       0       0
     269             0.0             0.1            0.95       0       0
     270             0.0            0.15            0.95       0       0
     271             0.0             0.2            0.95       0       0
     272             0.0            0.25            0.95       0       0
     273             0.0             0.3            0.95       0       0
     274             0.0            0.35            0.95       0       0
     275             0.0             0.4            0.95       0       0
     276             0.0            0.45            0.95       0       0
     277             0.0             0.5            0.95       0       0
     278             0.0            0.55            0.95       0       0
     279             0.0             0.6            0.95       0       0
     280             0.0            0.65            0.95       0       0
     281             0.0             0.0             1.0       0       0
     282             0.0            0.05             1.0       0       0
     283             0.0             0.1             1.0       0       0
     284             0.0            0.15             1.0       0       0
     285             0.0             0.2             1.0       0       0
     286             0.0            0.25             1.0       0       0
     287             0.0             0.3             1.0       0       0
     288             0.0            0.35             1.0       0       0
     289             0.0             0.4             1.0       0       0
     290             0.0            0.45             1.0       0       0
     291             0.0             0.5             1.0       0       0
     292             0.0            0.55             1.0       0       0
     293             0.0             0.6             1.0       0       0
     294             0.0            0.65             1.0       0       0
     295             0.0             0.0            1.05       0       0
     296             0.0            0.05            1.05       0       0
     297             0.0             0.1            1.05       0       0
     298             0.0            0.15            1.05       0       0
     299             0.0             0.2            1.05       0       0
     300             0.0            0.25            1.05       0       0
     301             0.0             0.3            1.05       0       0
     302             0.0            0.35            1.05       0       0
     303             0.0             0.4            1.05       0       0
     304             0.0            0.45            1.05       0       0
     305             0.0             0.5            1.05       0       0
     306             0.0            0.55            1.05       0       0
     307             0.0             0.6            1.05       0       0
     308             0.0            0.65            1.05       0       0
     309             0.0             0.0             1.1       0       0
     310             0.0            0.05             1.1       0       0
     311             0.0             0.1             1.1       0       0
     312             0.0            0.15             1.1       0       0
     313             0.0             0.2             1.1       0       0
     314             0.0            0.25             1.1       0       0
     315             0.0             0.3             1.1       0       0
     316             0.0            0.35             1.1       0       0
     317             0.0             0.4             1.1       0       0
     318             0.0            0.45             1.1       0       0
     319             0.0             0.5             1.1       0       0
     320             0.0            0.55             1.1       0       0
     321             0.0             0.6             1.1       0       0
     322             0.0            0.65             1.1       0       0
     323             0.0             0.0            1.15       0       0
     324             0.0            0.05            1.15       0       0
     325             0.0             0.1            1.15       0       0
     326             0.0            0.15            1.15       0       0
     327             0.0             0.2            1.15       0       0
     328             0.0            0.25            1.15       0       0
     329             0.0             0.3            1.15       0       0
     330             0.0            0.35            1.15       0       0
     331             0.0             0.4            1.15       0       0
     332             0.0            0.45            1.15       0       0
     333             0.0             0.5            1.15       0       0
     334             0.0            0.55            1.15       0       0
     335             0.0             0.6            1.15       0       0
     336             0.0            0.65            1.15       0       0
     337             0.0             0.0             1.2       0       0
     338             0.0            0.05             1.2       0       0
     339             0.0             0.1             1.2       0       0
     340             0.0            0.15             1.2       0       0
     341             0.0             0.2             1.2       0       0
     342             0.0            0.25             1.2       0       0
     343             0.0             0.3             1.2       0       0
     344             0.0            0.35             1.2       0       0
     345             0.0             0.4             1.2       0       0
     346             0.0            0.45             1.2       0       0
     347             0.0             0.5             1.2       0       0
     348             0.0            0.55             1.2       0       0
     349             0.0             0.6             1.2       0       0
     350             0.0            0.65             1.2       0       0
*SET_NODE_LIST_TITLE
Piston Motion
$#     sid       da1       da2       da3       da4    solver       its         -
         1       0.0       0.0       0.0       0.0MECH      1
$#    nid1      nid2      nid3      nid4      nid5      nid6      nid7      nid8
       246         0         0         0         0         0         0         0
*SET_PART_LIST_TITLE
ALE Mesh
$#    pid1      pid2      pid3      pid4      pid5      pid6      pid7      pid8
         1         0         0         0         0         0         0         0
*SET_MULTI-MATERIAL_GROUP_LIST_TITLE
Water
$#  ammsid
       102
$# ammgid1   ammgid2   ammgid3   ammgid4   ammgid5   ammgid6   ammgid7   ammgid8
         1         0         0         0         0         0         0         0
*END
