July 26, 2023 at 2:24 pm
I have the same issue.
- old license file installed and server started.... works fine.
- stop the manager
- install new license file
- start the manager...... it starts but then stops after 5 seconds.
flexnet log:
10:14:01 (lmgrd) Server's System Date and Time: Wed Jul 26 2023 10:14:01 Eastern Daylight Time 10:14:01 (lmgrd) pid 532 10:14:01 (lmgrd) SLOG: Summary LOG statistics is enabled. 10:14:16 (lmgrd) The TCP port number in the license, 1055, is already in use. 10:14:16 (lmgrd) Possible causes: 10:14:16 (lmgrd) 1) The license server manager (lmgrd) is already running for this license. 10:14:16 (lmgrd) 2) The OS has not "cleared" this port since lmgrd died. 10:14:16 (lmgrd) 3) Another process is using this port number (unlikely). 10:14:16 (lmgrd) Solutions: 10:14:16 (lmgrd) 1) Make sure lmgrd and all vendor daemons for this 10:14:16 (lmgrd) license are not running. 10:14:16 (lmgrd) 2) You may have to wait for the OS to clear this port. 10:14:16 (lmgrd) Retrying for about 5 more minutes 10:14:34 (lmgrd) Still trying... 10:14:52 (lmgrd) Still trying... 10:15:10 (lmgrd) Still trying...
- so I killed the lmgrd processes and restarted the manager... still stops by itself after five seconds.
- killed the lmgrd processes again, reinstalled the OLD license file, started the manager...works fine.
