Brennan Donovan
I had no idea about the walls and while they are there for thermal reasons, I'll first try to get them functioning as thin surfaces.
To clarify, I should try building a new model from the fluid volume first, using a subtractive method to allocate space for the solids, "unhiding" or building the solids into the fluid volume, and using thin surfaces to contain the model? Once that's complete, use named selections in SpaceClaim (or Mesh) and ensure that all solids are accounted for before moving to meshing?
Thank you so much for you help, I just want to make sure I have this correct.
