Hi Arda,
Here "y_vector" should be the position vector, but if you look at the data inside this vector it turns out to be a single number with value -1.925e-07. I believe that might be why you are getting incorrect results. I would suggest you to check the dimensions of all matrices and see if that helps.
Amrita
