July 27, 2023 at 11:40 am
I see, but the problem is that, using a smaller value for the pressure deviation, it works fines and converges (although it's effects are very small).. I'm having a hardtime troubleshooting when the simulation doesn't converge, I fiddle with the initial values and the turbulence parameters which in actual fact is almost always the reason of divergence, it's very common I get a "Turbulence Viscosity Ratio limited to 50000" message while running it. Im thinking now about possibly the Courant value is a bit high, or maybe the relaxation factors are not "optimal"... If you have any suggestion, it would be greatly appreciated!!
Thanks for the response NickFL :)
Sincerely
Kaue
