July 28, 2023 at 5:50 am
Hi Gary,
You can combine native parametric analysis capability along with Python using the Python code object in Mechanical to achieve what you want (i.e. exporting files after each solution):
Now coming to your parallel processing query, with the above-suggested approach, each design point is run after previous finishes. If you want multiple parallel instants, you will need multiple licenses to start separate mechanical sessions.
-Aniket
