July 28, 2023 at 6:56 am
While I haven't personally done the simultaneous coupling of Ansys Fluent with Rocky on an HPC cluster, in theory, setting up a 2-way simulation in Rocky on an HPC cluster should be similar to what you would do on a Windows or Linux PC. First, you need to set up your 2-way simulation in Rocky, just as you would for a simulation on your local machine. Once your simulation setup is ready, you can submit the job to the HPC cluster. When the job starts, Rocky will launch Ansys Fluent and establish the coupling between the two solvers. Just, make sure that both software packages are installed and properly configured on the cluster and that they can access the license server (if one is being used).
