Levente Bicskei
There is no surface inside the bodies. Two transparent solid bodies:
Only one:
Clearly the problem is that somehow the surface in contact is not only in contact, but also coincident. The question is how can I solve this problem without remodelling the bodies? Because at the end I'm going to need that hundreds of specific names of these solid bodies what you can see on the attached picture on my previous reply.
