Amrita Pati
Hi Nathan,
The simplest approach would be to use the polygon object. If you have the equation of the spiral then you can set the vertices of the polygon using the equation. It is important to note that linear interpolation is used between the neighbouring vertices of the polygon. But if you have sufficiently large number of points/vertices then the structure should be smooth enough.
Amrita
