I am actually using CFD fluent to do the analysis (Conjugate Heat Transfer Analysis) and only using FSI to see the temperature changes on the solid body. The problem I am talking about is to set different flow times in ansys fluent to see the temperature changes in the body. For example in the image below the body temperature changes from 300 degree to lower temperature when air with 27 degree celcius temperature flows with 0.5 mach speed. Now here analysis time is 1 second written which I beleive is air flow time ovewr the body. I want to variate this time to see when does the body reaches a normal temperature. But even in transient analysis, when I change the flow time and import the results to the body using FSI, only the source time changes while analysis time remains the same.
