@peteroznewman, thank you so much for your reply. I have an update on the assembly. I have made the door and bush the 'rigid body' and made the hinge and pillar flexible. I was now able to get the stress value on the hinge leaf. The reason behind making the door rigid is that the door is made of structural steel having superior YTS and UTS, while hinge is made up of aluminium alloy, which is much less stiffer than the door. Also, hinge being the weak link and prone to much stress, this should be the area of interest. Took the reference from here:
https://forum.ansys.com/forums/topic/regarding-force-and-moment-in-ansys-static-structural/
I hope my understanding is correct. Moreover I'll try doing the steps yopu mentioned above rerun the simulation
