Duplicate the analysis and use Part Transform to rotate the parts to different angles.
You could potentially create a Design Variable in SpaceClaim or DesignModeler to rotate the parts and have a single analysis with an Input and Output Parameter and a Table of Design Points to rotate the door to different angles.
