Lorenzo Vecchietti
Hi Naresh,
since it is happening on many small elements, my first suggestion would be to try and improve the mesh. If the mesh is too coarse, then some objects are implicitly filtered out. "Too coarse" means that the dimension of the minimum element of the mesh is larger than the dimension of the object you're trying to mesh.
Best regards,
Lorenzo
